Best place to put FPR?? Before or after the rails?
I was wondering where is the best place to install the FPR. It is going to be a forced induction motor. Before the rails or after?
8 sec potential, 12 sec slip
After the rails for sure! You are going to get a slight pressure drop across the rails, so you want to make sure that the final pressure in them is set to 58psi (or whatever), not the initial before going into the rails.
Also, for FI you will need to get a 1:1 boost referenced FPR so that it will raise the pressure with boost to keep the psi steady.
