which fuel pump?
Old 04-06-2007, 05:03 PM
blown00ls1's Avatar
Default which fuel pump?
I am pretty sure I need a new fuel pump, mine is acting up like no other. Which fuel pump should be used for a procharged ws6? 60lb injectors... and more info if you need it?
Old 04-06-2007, 05:32 PM
NoGamesLS1's Avatar
You cant go wrong with racetronix. You might need to upgrade to their dual intank or add an inline depending on hp/boost number
Old 04-06-2007, 05:38 PM
blown00ls1's Avatar
boost is 10lbs, horsepower should be around 450-475 re-tune.
Old 04-06-2007, 10:30 PM
NoGamesLS1's Avatar
I would just get the single intank racetronix. Call your tuner and make sure
Old 04-09-2007, 01:18 AM
Anthony Williams's Avatar
Just put a Reacetronix from Thunder Racing in my '99 Z28 with no problems drop the tank and take your time , keep Thunders # handy if you need some tech suppport, those guys are great.
Old 04-09-2007, 07:19 PM
blown00ls1's Avatar
got a part number?
Old 04-09-2007, 07:25 PM
NoGamesLS1's Avatar
just go to thunderracing.com I believe its the only one
Old 04-09-2007, 07:46 PM
blown00ls1's Avatar
could it be this one:
135-F99-FPKG2 Racetronix Fuel System w/ 255 LPH High-Pressure Fuel Pump and Series II Plug-&-Play Wiring Harness (includes chassis ground & booster pump plug-&-play option), 1999-2002 LS1 F-body w/ plastic fuel module (bucket) & Plastic gas tank - Introductory Price
Old 04-10-2007, 02:44 PM
LS1AC-Cobra's Avatar
I also have 60lbs Injectors, I'm using a Aeromotive Eliminator which is like a overkill, a A1000 would be perfect for the Job, just don't like a In-tank pump
Old 04-10-2007, 06:10 PM
blown00ls1's Avatar
Ok so in that case I have to ask the question, HOW do you transfer from an intank, to an external?
Old 04-11-2007, 12:51 AM
LS1TECH Sponsor
Racetronix's Avatar
http://www.racetronix.com/RX-F99-FPKG-2.html
Thunder has these in stock.
Their Friday the 13th sale should be coming up as well....
Other Racetronix dealers may be running promotions as well.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old 04-11-2007, 02:42 PM
blown00ls1's Avatar
thank u
