Mototron 60# injectors
LS1TECH Sponsor
They will work ok in your application, but are not necessary unless you plan to make more power in the future. You may sacrifice a slight amount of mileage & drivability, but you should not have any problems if properly tuned.
If you are not planning on adding a few hundred more HP & have not purchased them yet, then consider a smaller size.
