-6 crossover on Aeromotive rails okay to run for 1000rwhp?
Sorry guys I know it's the wrong section but I figured this is the best place to ask. I'm upgrading my fuel system to -8 feed lines, aeromotive rails etc. The crossover for the rails is going to the back of the intake. I tried to run a -8 crossover but the fittings hit the back of the firewall on the driver side. No matter which way I turn them it's no go. So will a -6 be suficient or do I have some other option-I'm not going to cut the firewall-that's for sure. Basically a -8 feeds the front of the rail on the passenger side-a -6 will be crossover from the back of the pasenger rail to the back of the driver rail and at the end of the driver rail is a magnafuel regulator which has a -6 out to the stock return line.
Will this cure my fuel pressure drop at wot.
Thanks!
Thanks!
Well, a -6 feed and crossover is sufficient for much more than 1000rwhp so you -should- be fine, but I generally like to keep the crossover the same size as the feed line.
Why not??
Originally Posted by eb02z06
It's the Aeromotive rail that uses a -8 inlet with a o-ring-so i can't cut it down. Damn C5's!!!!
Man what a pain in the ***!!!! After cutting the cowl on the driver side I found the fitting on the passenger side also hit-it was a HUGE pain to get the manifold on!!!!! I don't know how the rest of the Vette guys are running rails or if this is just specific to the aeromotives? So basicaly my inlet is the passenger side front rail-the cross over is at the back-8 and the regulator is at the front of the driver side. Fired it up last night and checked for leaks and there was none-all seemed good. One thing that I did notice was that fuel pressure drops immediately after the car is shut down-Is this normal? I'm using a magnafuel boost refrenced fuel regulator.
Unless there's a check valve in the pump, or added into the feed line, the fp will drop quickly.
You could add a check between the pump outlet, and the feed line.
I don't suggest the check be in before the pump, as that will introduce uneeded restriction to pump supply.
No big deal. As long as it stays up when the pumps are running !!
Im using a single -8 Alu hardline to the front of the car, an Aero fuel dist block, then into a pair of -6 lines, one to each Aero rail. These then tee into a single -6 line to the Maganfuel reg, then to the tank.
My FP is rock solid at all times.
