Stock 98 C5 Regulator Questions
Does anyone make an adjustable & boost referenced regulator that fits in the stock C5 regulator location on the return style rails?
Or is it already boost referenced based on this thread
http://forums.corvetteforum.com/show...ight=regulator
If not can someone tell me how to add a boost referenced regulator to my fuel system while still using stock rails?
Will the test port on the end of the stock rails work well enough or big enough to use as a return port to add a regulator onto?
Originally Posted by cablebandit
the regulator is already boost/vacuum regulated....i used that setup for a few years
Is it 1:1 referenced? Up to how much power were you using it to? How much pressure were you seeing with it?
