Fuel Injector Sizes
Fuel Injector Sizes
I have a '99 T/A WS6. I have a FAST TB and intake (78mm). I also have a new LS1 air lid. Do you have a suggestion on changing my stock injectors? What size, what make, etc...? I don't want to give up a lot of gas mileage, but I would give a little to get more performance with the changes I've made.
When you're ready for new injectors, just make sure to get them flow-matched (it's cheap and worth a few hp, easier when you go to tune it, too), eg. www.rceng.com's.
When you make more mods than what you said above, they also have a calculator of what size to get... or whether to upgrade your injectors at all...
I always go for the biggest injectors you can get. It don't matter if they are overkill for your engine. If you are injecting at 95% now, you are spraying raw fuel onto a closed inlet valve for up to 70% of the time. Lots of puddles.
The bigger the injector, the more you use when your inlet valve is OPEN, the less spray when its closed.
