Fuel Pump and Injectors - enough?
I thought i had this mapped out nicely, but there has been some recent doubt in my "camp" about whether i'm going to be able to supply enough fuel to make 700whp....
Like i said, i'm lookgin to make 700 to the wheels, give or take a few. Currently, the setup is with 2, 255lb walboro fuel pumps, and 60# injectors. I went with 60#ers b/c they were the largest high-impedance injectors i knew of. Recently, it has come to my knowledge that there is a company that makes 83# injectors in high impedance, but they're like $200 or $300.
I'm willing to spedn the extra money on the injectors if need be, but will twin 255lb fuel pumps be able to push enough fuel to make 700 or 750whp?
Will the 60# injectors be enough to make 700 or 750whp?
Thanks! This is all going together by friday (i pray), so quick repsonses are appreciated!!!!!!
It will be more than enough as long as you have a boost referenced fuel pressure regulator.
I've run the 60's as high as 5 bar base pressure and they still work flawlessly.
Originally Posted by SSilverSSurfer
700hp is not gonna be enough for you, your gonna wanna turn that bad boy up. good luck
i just wanna know if 60#ers will be able to support that kind of power and if 2 pumps will be able to push enough fuel
is that going to be a major issue?? or will 60's sstill be ok?
Originally Posted by SonofaBish
haha... well tha'ts not the question my friend...
Originally Posted by ty_ty13
fuel pressure regulator is a must with 60#ers and any kind of boost..
Does a bear **** in the woods? Your 60 lb injectors are good to around 800-850 rwhp. You picked the right injectors for sure for your power goals. Your pumps are good to 1000 rwhp.
