what injectors..
what injectors..
I have a completely stock fuel system right now. I'm full bolt ons, cam (TRex), about to install an NX wet kit, 150 shot. I'm going with the racetronix pump kit. (fuel pump and harness) 42 pounders or is that overkill?
N8, I don't see stock injectors handling this, what would you recommend? I'm already planning another build so I'm keeping this one on a tight budget. My goal is high 10 cam only, mid-bottom 10s on the juice. I won't be able to re-use 42lb injectors on the next build..muchless anything else.
