differential leak
differential leak
Okay, I thought I already posted this but can't find it. There is a leak coming from a plastic valve of some sort on the passenger side of the differential. I'm not sure what this piece is and its function. Can it be replaced? Any help would be greatly appreciated. Oh this is on a stock gm rear axle from a 2000 transam.
LS1Tech Sponsor
That is the axle vent and all you can do is maybe raise it up higher with a piece of vacume hose. If you remove and plug the hole you will have the rest of the seals start to leak.
