My Midwest Chassis Fab. 9"
Hello all, finally got my rear and installed it today, first off aside from the lenghty wait of this product, this thing is pure sex.......i couldn't be happier and the long wait was well worth it, everything went together very smoothly as well. Only part that sucks is I can't use my Lakewood driveshaft loop anymore, it hits the torque arm setup which makes it lower then the mounting points, know i'm not sure if I'm going to sell it or maybe even try to modify it to work. The torque arm also hits my true dual setup, which is my fault because I designed it to be really close to the floorpan, no biggy, instead of putting the eyelit from the front of the TQ arm in the second from bottom hole I had to put it into the second from top hole and adjust everthing accordingly. All in all awesome product and worth every penny. Thank you Eric for putting up with all my calls and selling a great product.
My setup is:
Stock lenght Fab. 9"
31 Spline Moser Axles
Tru-Trac
4.11 gears
Strange Nodular Iron Case
Long TQ Arm Setup
Backbraced
You can see all the pics at.....
http://s178.photobucket.com/albums/w...la/New%20Rear/
Here's a few.....
My setup is:
Tru-Trac
4.11 gears
Long TQ Arm Setup
Backbraced
Here's a few.....
