4.10 gear install
Old 01-07-2009, 11:25 AM
boofthese's Avatar
Default 4.10 gear install
How hard is it really ?
I have a 02 z28 6sp, ABS, no TCS.
Im real good handyman wise, but this will be the first gear install ive done, Im real good at following directions and what not, so i figure if i had a install guide or something to go by i should be able to tackle it no prob.
ANyone know where i could possibly find one ?
Old 01-07-2009, 12:13 PM
FirstYrLS1Z's Avatar
https://ls1tech.com/forums/gears-axl...r-r-gears.html
Old 01-07-2009, 12:41 PM
boofthese's Avatar
sweeeet thanks
Old 01-08-2009, 10:23 AM
mvvette97's Avatar
you can do this no problem. I'll help ya all I can over the internet.
Old 01-08-2009, 10:29 AM
WYATT318MOPAR's Avatar
Not that big of a job to tackle, just get you the right tools before you start. Not like you have to spend a fortune just get some basic indicators that will work long enough to do what you have to do. Harbour freight actually has some nice cheap precision tools.
1. Dial indicator & magnetic base
2. Dial caliper
3. 6' straight edge to measure pinion depth "square stock works really good"
4. Paint to get a pattern on the gears with
5. Plenty of clean rags and brake clean
Old 01-08-2009, 12:13 PM
w3s1c0a5t's Avatar
We just got thru doing this yesterday. Just go slow. Follow a good set of directions and measure everything twice.
Good luck sir.
