poping noise from tranny
Old 02-03-2009, 08:31 PM
nealws6's Avatar
Default poping noise from tranny
Is a 00 TA, rebuilt t56,spec 3, h/c, lca,drag radial, all bolt ons
1. broke 10bolt put a 9", 411 gears with spool when i turn slow shakes the hell of the tranny is that normal? (is not the rear end)
2. Going strait, ONLY when i let go of the gas, feels like the tranny goes back and forward, could hear like a popping sound. Any idea what could it be. THANKS FOR ANY INFO.
Old 02-04-2009, 04:33 AM
EPP
EPP's Avatar
No, it is not normal. I see you have all bolt ons, I take it that includes an aftermarket torque arm as well. Check out this link. http://www.exoticperformanceplus.com...php?service=58
Also, make sure your transmission mount is not broken, as it can cause a popping sound when it is broken. Bob
Old 02-04-2009, 02:14 PM
nealws6's Avatar
have a uim torque arm adjustable with DSL and transmission mount is good.
SS1875's Avatar
Definitely check out what Bob said....TA, Trans Mount for any breakage.
Old 02-04-2009, 08:38 PM
nealws6's Avatar
check everything and looks good. sounds like the clutch, when I press it and releast it fast sounds like it hits hard. any idea?
Old 02-04-2009, 09:04 PM
proelky's Avatar
It sounds like a mount, cracked bellhousing, or torque arm issue.
