F-Body Axle Question
Askin this for a friend, on a fourth gen f-body, are v6 and v8 axles interchangeble, and is there any difference between the driver/passenger side?
Very important though. If you have ASR, you need to get axles with reluctor wheel provisions. These are refered to as 4 channel axles.
If you don't have ASR, then you have a 3 channel rear with no reluctor wheel on the axle. With a 3 channel you can use either type axle.
With a 4 channel you have to use 4 channel axles.
