Quick Performance Ford 9" Housing
#81
Please buy from an LS1tech sponsor, this website would not be here if it wasn't for the sponsors. Bob
#83
I wonder how much it would cost to have someone fabricate a custom torque arm then? Or are you a master fabricator that can build your own torque arm with the correct geometry?
I don't think so, but I didn't even ask because I don't have a need for electronically controlled braking. But hey, if you need help with your braking capabilities, maybe the QP isn't for you.
I don't even want to respond to this man. See my price breakdown on the first page of this thread.
1. Do you even read the threads in here? Half of them are complaints about Moser 9" housings, and you claim that they're a "great product". Either the gears that they setup make ungodly noise, or the TA bracket bangs on the tunnel over every bump in the road. Or both..... great product!! How about mediocre at best.
2. Not only that, but the Moser housings have the same "non 3channel ABS" issue that QP has. I really don't get your logic on this at all.
3. The Moser 9" housing/axle package is more expensive than the QP by over 200.00.
Mike
Mike
moser part number B9HP2 on there website is 1080. and no one pays that price i bought my last one for 870 to my door.
and the gears isnt al moser problem. just set it up for self or are you not that good of a car guy.
and yes i can build my on torque arm. i have built three. they work great. hell i build alot of my own stuff. i dont with the rear. cause doing a one off is pricey.
and Bod form EPP is the **** on moser stuff. and he is right. thank good for the continued support of true ls1tech customers
so you know mike. this is my last post in here. i just started my first post to let people know that in the past QP has broke welds.
#84
And QP's price is 875.00 for the same options. Actually you get more with the QP housing because it comes standard with drain and fill plugs. Those two plugs are added options on the Moser which adds cost. I can go round and round with you as long as you like man. Every other 9" housing out there will cost you more and/or probably have "clunking" issues with hitting the tunnel.
Have a good day.
Mike
#85
I would have bought from a vendor, but didn't find any that were selling the QP housing. And I DO,,,,, and HAVE bought from vendors on here as well as other forums over the last 10 years. Thousands upon thousands of dollars in fact...... I'm fully aware of the "circle of life" when it comes to retail business and public forums, but I'm not going to limit my choices just to make a LS1 vendor happy.
Mike
#87
anyone know if the offer the 3 and 4 channel options? although its not necessary for me, the wife doesnt mind taking the car for a ride here and there, and anything i can keep on the car to help her control it if she "gets squirrely" is what im looking for
#88
Another thing to keep in mind is this, I am going to be hitting my car with some power this year, and did not want to risk the stock driveshaft. I bought one of the PST shafts from EPP. They told me that alot of the guys with the moser had vibration problems, and one of the cures was to run a driveshaft that was 1 inch longer than stock, THAT WAS NOT THE CASE WITH MY QP REAR. I took their advice and when it came in, it would not fit. TOO long, I got back with BOB and Drew (SUPER GUYS) and gave them my measurements and they told me that was close to the stock measuerment within a 1/16. So I shipped it back to them and they shipped me one that was stock length. Fit fine no problems. Just keep that in mind. If you are going to buy another shaft make sure you measure it first....
I believe the stock shaft will fit perfect witht this QP rear, but if you are replacing the rear because you feel you have enough power to break it, you probably have enough power to break the stocker. When I was at the track another member on this site was racing his camaro, stock drivetrain, I got to talkin to him and he told me he had broken 1 rear already. My last pass of the night I seen them pushing his car back, after talking to him he said he broke the driveshaft , and the rear. He's cool now he bought a moser and a pst shaft.
But keep that in mind.
#89
Here it is, back from powdercoat in silvervein color. It now matches my BMR Kmember.
Spohn LCA relocation brackets I welded up this past saturday.
Modified stock sway bar mount.
LT1 Backing Plates
That's about it for now. Just need to finish the gear setup and clean up the underside of the car. I also need to bend up some brake lines and fab up a mount for the brake line Tee.
Mike
LT1 Backing Plates
Mike
#91
IMO ABS is kinda like a cane, it's there if you need it, but for able bodied people it's very annoying.
Mike
#92
4 channel i dont care about (dont need traction control), but i would like run at least a 3 channel and keep my ABS cuz its still a street car. has anybody found a way to make this rearend work with the 3 channel system and keep the ABS?
#93
^^^^ i wonder if you ordered the thried member from moser if it would work. moser has a 3 channel. and i think midwest does too. but you might have to modify the center section. like the drill a hole or somthing.
#95
yeah that was my thinking also. even if you ordered a 3 channel carrier from elsewhere you still might have to mount the sensor on the housing somehow. can anybody confirm this? if you order a moser housing with 3 channel will it be plug and play? or is there more to it? hopefully somebody can answer this cuz the ABS issue is the only thing holding me back from buying one of these....
#96
LS1Tech Premium Sponsor
there is a housing mod, and a center section mod required for 3ch ABS. I was the first one to offer 3ch abs on a production type 9 inch rearend for the f-body. it is required to have both components(housing and center) to be able to install the setup. there are tolerances that are crucial to the operation of the system.
#97
#100
Race car - ABS delete is great. Less weight, less clutter.
Street car - Sorry, I've NEVER met someone that can out-brake a late model ABS system. And I doubt you can also. Use non-ABS brakes without failing at it, is completely understandable. But you never know when you're going to have to panic stop and the extra several feet can make a difference.
