Quick Performance Ford 9" Housing
Here's some pics:
Torque Arm Mounted To Housing
Torque Arm Mount
Thanks,
Mike
On another topic, Quick Performance seems very confident it'll take the punishment of a car making 1000hp. I'm just trying to find out how hard it's actually been pushed or if there are any known issues with it. My car won't be pushing the limits of this housing as is, but I'd like to know that I'm buying a rearend that I can grow with.
Mike
Mike
Yes but now you have to buy the Center Section, the Differential Unit, the Torque Arm, the Torque Arm Mount, the Driveshaft Saftey Loop, the Gears, and spend approx $300 - $400 for someone that knows what their doing to set up the gears for you. And that still dosen't include a new Driveshaft. Just saying, add all of that up, and you are really close to the price of the Fab 9".
It may be a very nice at a good price. But I like the deals that Eric at MWC cuts for people when they order more stuff with the rear.
OK the torque arem mount is included in the housing quoted price, but if you already have the torque arm, safety loop, and are more than capable of setting up your own center section then you end up saving some coin. I understand what you're saying and I'm not disagreeing with you. I'm merely saying that there is more than one way to skin a cat, and the way I approach it will personally save me around 800.00++.
I don't who you're paying to setup those gears, but they're way over-paid lol....
Here is what I'll have into mine by choosing my own parts and setting up the gears/assembling it myself:
Strange Nodular S Case w/3.25" Carrier Bearing - 210.00-300.00
31 Spline Detroit Locker "H" Case 3.25" Bearing - 250.00-350.00
3.89 Gears - 100.00-150.00
Master Bearing/Shim Kit - 98.00
Aluminum Pinion Support - 85.00
Forged Steel 1350 Yoke - 75.00
Housing/Moser Axles/TA Bracket/Bearings/Studs = $945.00/shipped
Add another 100.00 because I'll probably have it powdercoated locally to match my BMR Kmember.
Mike
Strange Nodular S Case w/3.25" Carrier Bearing - 210.00 New
31 Spline Detroit Locker "H" Case 3.25" Bearing - 210.00 Used
3.89 Gears - 100.00 Used
Master Bearing/Shim Kit - 98.00 New
Aluminum Pinion Support - 85.00 New
Forged Steel 1350 Yoke - 75.00 New
Center Section Total Price = 778.00
Total 9" Rearend Price = $1723.00
Mike
Yeah that might be the case but as far as im concerned im gonna set it where i want and leave it. Ill let ya know how it turns out.
the rear end comes with the axles, bearings, hardware, and It most definately comes with the torque arm mount. It is a very heavy duty piece, and has the heavy duty center with the longer bores so there is more to weld the axle tubes to, and the price was great. I paid 875 for the housing to my door, and 900 for a nodular center section with a detroit locker and 3.75 gears. total for everything 1775 not bad. Also for you to consider, look at how many post you have seen about this quick performance rear end, and compare it with how many negative things people who have the moser have said, make up your own mind bro. (there is one negative post on this site and it is filled with MY buddy, or my friend garbage, First hand experience is what matters, if you didnt do it how do you know the guy turning the wrench is not to blame.) Me personally I am very happy with it, If you get it and go to install it call quick performance and they will gladly help you with advice on the install. Or feel free to PM me and I will gladly help with the few things I learned putting mine in. Hope this helps Just my two cents
and Yes you do have to take the torque arm off to adjust the pinion angle. not a big deal, set the rear up with your proper angle to begin with and you dont have to touch it again. The only thing an adjustable torque arm does is changes pinion angle, there is no secret launching voodoo in pinion angle but that is another argument.
