Quick Performance Ford 9" Housing
If anyone else has one, feel free to speak up. I'd like to get all the feedback, good or bad.
Mike
The Strange center case is at the powdercoater now, then when the QP housing gets here, it's going to the powdercoater too. Getting the QP housing done in Silvervein to match the BMR Kmember:
Mike
Mike
I think the biggest issue is getting the reluctor ring attached behind the ring gear somehow. With the 9", there's not much room unless you had some custom gears, or custom carrier made. Then you would need to attache the sensor to the housing somehow also.
Someone correct me if I'm wrong. It's been awhile since I've cracked one of these ABS rears apart.
Mike
Mike
Well 4 channel has reluctors out on the axles. Basicly all you need to is to order axles with provisions to press the reluctors on. that is about a $100 option from most companies.
Other question is anyone having clearance issues with that mount located at the top?
You should call them and ask if they offer the 4 channel option. Maybe ask them if they offer a 3 channel as well just to let everyone know.
