Quick Performance Ford 9" Housing
1. PHB wont go in even with beating it the hell out of it
2. I have to drill hole bigger for shocks.
3.PHB hole will need to be drilled bigger to!
Mike
drilling shock and panhard bolt holes isnt a issue if you have the tools at the house. Ive red a few post on here with people with moser having the same problems
Like SIC LSX mentioned that he ran into, not everyone has a bid drill and drill bit laying around and having to go out and buy one or search for one down when wanting to install your rear end can be a pain.
That is just another one of those added feature we do like adding on brake line tabs, hose mounts, e-brake cable brackets(98-02), and stock style sway bar mounts. These all come at no extra charge when buying one of our housings.
For those on a budget we can sell just the housing, torque arm, and cross member. Or we can put you into a housing an axle package. We have many different levels we can start you at if you are wanting to put together your own components.
Midwest has by far the best setup out it was just out of my price range. Trust me i would love to have one.
Qp will most likely get my money in the spring time.
Which strange case did you go with, pro, or s-series? I had a pro case in a moser once before and thought it was a rather beefy unit.
I had planned on outfitting one just like you listed, maybe spring for gun drilling the axles tho, and I'll set them up in the mill at work and drill the "lightening" holes in them myself, that moser charges $40 bucks to do.
I've only seen 1 qp rearend, and the quality seemed on par with what moser sells, if not better.
narrowed 2.5" each side
35 spline CM drag spool
35 spline moser axles
Strange Nodular Iron S-Case, Aluminum Daytona Pinion Support, 1350 Billet Steel Yoke, Motive Performance Gears, & Timken Bearings
4.30 gears
$2,100 shipped!
i personal dont like mosers setup for the torq arm! It weighs more too
You have guys like us that are hitting the track every chance we can testing our own product, because it is only make us go faster with the stuff we produce in house. In return that means our customers are going to keep getting not only good product but good tech help from our own testing.
This is also a reason other manufactures come to us to test what they are producing. Us testing our own product is one thing you do not see from a lot of other manufactures. We are a company that wants to keep growing based on knowledge and not based on how much product we can push out the door, and we are not someone middle manning everyone else's products.
The product we do offer when we put a housing package deal together also comes from our own testing, we chose items that are based off of performance gain with out issue. We are not offering product based souly off what our biggest profit margin is or just based off the fact that is all we can get.
4.30 gears
$2,100 shipped!
Plus you would not of had to spend the time trying to find a drill and drill bit to drill out the shock holes because that is something we do before the housing leaves the shop, we ask the customer what current shocks they have on the vehicle plus if they have any future plans for changes. Along with the fact you don't have to use zip ties to hold your brake lines in place or muffler brackets to mount sway bars, our housing has brake line clips and E-brake cable brackets attached to the housing along with factory style sway bar mounts.
Our package is a true fabricated housing that comes with a torque arm and cross member for $2650 shipped(depending on location). On top of that we are not only building our own product we are out testing it every weekend we can.
With a package purchase from us we offer great prices on our lower control arms, pan hard par, and anti roll bar that we also build in house. We can also get you good deals on shocks, wheels, and just about anything really. Along with our custom work we can build a very good working relationship to take care of our customers needs for a long time.
