easy question, someone knows the answer
Old 02-11-2009, 08:45 PM
run em down's Avatar
Default easy question, someone knows the answer
does anyone know the torque specs for a ta rearend girdle?
i put mine on a few years ago and will be removing it when i replace my wheel bearings. cant remember the specs. also any tips for the bearing change will be helpful, thanks.
Old 02-12-2009, 05:18 PM
alamantia's Avatar
for which bolts, the 10 or 12 that affix it to the dif or the 2 jack screws? jack screws are only 10ft/lbs if i remember correctly.
Old 02-12-2009, 06:59 PM
Justins00ss's Avatar
Nope they are 5in/lbs not ft/lbs...
My buddy over torqed mine and when I went to remove it one of the jack screws snapped in half on me.
