Tq. Arm Bolts -part# or size???
Old 04-08-2009, 04:21 PM
RENE'S RAGE's Avatar
Default Tq. Arm Bolts -part# or size???
I need the bolts that holds the torque arm bracket to the frame of the car. GM part# or size of bolts. The two bolts on each side. Installing MWC FAB 9 but sold the bolts along with my old Spohn torque arm. Thanks
Old 04-09-2009, 10:56 AM
cam
cam's Avatar
The stockers are 14mm but go to your local fastener specialist shop and ask for two grade eight 9/16" NF seven inch length plated bolts with lock nuts and your good to go for a fraction of the cost the dealer would charge. Bolts and clips through the stealership are absurdly priced
Old 04-09-2009, 08:06 PM
Thanks, but I need the 4 smaller bolts for the torque arm/driveshaft loop bracket,near the transmission.
Old 04-09-2009, 08:33 PM
FirstYrLS1Z's Avatar
the 4 smaller ones are 8 mm,don't know pitch or lenght.
Old 04-10-2009, 10:04 AM
Thanks, that's a start, I have alot of bolts laying around here, just been busy with other things to crawl under the car and try them. Going to install rear this weekend and wanted the right bolts. Thanks again.
Old 04-12-2009, 09:43 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
those are 8mmX1.25. probably need ones about 25mm ong with a washer as well. get ones rated 8.8 or higher.
Old 04-12-2009, 10:25 AM
Thanks again Eric.
