Moser 12 bolt install coming soon I have a Q about the brakes
Old 07-15-2009, 08:17 PM
TRUCKIN's Avatar
Default Moser 12 bolt install coming soon I have a Q about the brakes
I bought the housing and axels used but never used. I have all parts to put it together but im not sure where the bracket that holds the caliper goes. My car is a 97 trans am. Im not sure if it matters. The length is the same. I have to put c-clip eliminators on and thats the hold up. Where does the bracket go for the stock brakes???
Old 07-15-2009, 09:40 PM
BadBandit69's Avatar
You need backing plates. Thats what the caliper bracket bolts to. The backing plate has to be slid on the axle before your have your c-clip eliminator axle bearings pressed on to the axle. The backing plate is also what holds the axle shaft in the axle tube.
Old 07-15-2009, 09:59 PM
TRUCKIN's Avatar
Thank you. Does anyone have a part number or even a picture of the backing plate? Where do you get them at and how much?
Thanks for the help
Old 07-16-2009, 04:29 AM
EPP
EPP's Avatar
Thanks for the help
You take the backing plates off the old 10 bolt from your car. Here is a copy of the Moser instructions. http://www.exoticperformanceplus.com...html?item=1263
I also have step by step instructions along with pictures at this link for the Moser 9 inch, which will also help for the 12 bolt. Bobhttp://www.exoticperformanceplus.com/performance_parts/index.html?item=145
Old 07-16-2009, 07:12 AM
99Ls1fever's Avatar
We could use some pics!!!
Old 07-16-2009, 10:03 AM
TRUCKIN's Avatar
Exotic that does help but it doesnt show the installation with a c-clip elim. on. Im worried about the thickness of the caliper bracket and the c-clip elim. being so thick that the axel sticks out to far. The c-clip elim. is 1 3/4 thick and the caliper bracket is 3/4 thick.
