Made a bad move and took pinion bolt off w/out marking it
Was in a hurry to replace my seal and took the bolt out before I marked it. i don't have a dial indicator to measure load, am i out of GAS or anyone successfully put it back with no issues, while forgetting to mark the bolt?
First of all he never messed with the shim and second of all without the proper beam style torque wrench you cannot obtain a correct reading, third of all he doesnt sound like he knows all that much about rear end assembly anyway. In my experience, in order to crush the crush sleeve, I have had a socket and a 24 inch breaker bar, my buddy has had a 24 inch long pry bar holding the yoke and i would have to lean on it so hard it would about pick him up off the ground (this was rebuilding the 10 bolt out of the car). You see what im getting at. No damn way one could do this alone. Tighten it as good as you can and roll the yoke and make sure there is no abnormal slack, as well as no binding. Thats the best you can do at this point.
