Are 2 series carrier 3.73s worth it????
I think with the 2 series carrier the ring gear is thicker than the 3 series. I got a buddy that is cutting any where from 1.56 to 1.62 60 foots with his 3:73 2 series. So you should be fine
yes the two series gears that are lower ratio are a "thick" gear. the carier is offset more so it requires a spacer for a 3 series gear or the specific thick gear. ive ran 3.73 and 4.10 without issue for years
