Pinion Angle Off, Vids at the track
1 Post
Im not to happy with my 60 fts when I went to the track this past weekend. I was really hoping for better times and the car didnt want to hook up. Most of it could be the track is a shitty track now..but heres a video of the car leaving. Its not a fast car but should be faster than what it is
Could my pinion angle be off causing the car to spin and no squat hard. Im not Dumping the clutch at 5000 rpms Im trying to slip it around 2500 or so. Spins all of Second gear. Yea Im only on a 275/40 DR but dang..I tryed everything from heating the hell out of them, just turing them over, no air lots of air, dumping, sliping the clutch and it is just a turd..
No Front Sway Bar
Iv got the UMI short adj T/A
Adj Panhard Bar
and LCRs with Relo brackets..
Stock Shocks
I dont have a angle finder so I have no idea what its set at..
This is not a race car so I dont realy want to go adding QA1s but I would like to see a bit better times..maybe 11.9s..I know it has it in it..but second gear spins too much.
My dad raced me on one pass and he said 3rd gear he seen the car spin and try to move sideways like it does in second.
Should I try seting it and geting some 15 in wheels and bigger sidewalls so I can leave at 4000+ Rpms to stay in the power band..
http://www.youtube.com/watch?v=YRDtKSQ6b6c
No Front Sway Bar
Adj Panhard Bar
Stock Shocks
find someone good with chassis work to check it and set it up makes a big difference usually 4 degress down works good all purpose setup if the relocation brackets are adjustable put them on the lowest hole the torque arm may be binding up if so does nothing for you the agle finders are cheap get them antwhere
1 Post
Why is the car not wanting to squat? Could pinion angle have something to do with that? If so we played around with that today. It was at 0 to +1 on the ground, now its adjusted to -3 and doesnt bind or anything, the front of the car seems to raise a lot more now. Could that have been a lot of my problems?
What is your suspension setup?
he's right cars not suppose to squat the idea is lift the front end and transfer weight a littles not bad but to much squat suspensions to loose not gonna hook great if your have lift thats unloadin the tires because not transfering has to be balanced on the rear yes the change in pinion should help already did if you said you can tell the fronts liftin get some 90/10 front shocks too big help good luck
not terrible but the right balance of front lift and rear pushin down should equal 0 squat in a perfect world any movement up or down in rear is wasted motion but squat is better then lift
