in the market for a rearend? ck this out!
As many of you know I manufacture one of the best bolt-in rearends for the f-body, however I am also a direct dealer of Strange and Moser Engineering.
Strange offers the best 12 bolt, and the super strong and best bang for the buck S60. Moser offers the popular oem stamped style 9 inch that can be packaged for a real good deal, and the other fabricated 9 inch.
5 good rearends to choose from to suit your needs and budget. if you call me I am usually the one to answer the phone, am probably the most knowledgeable person in the f-body world on all the rearend choices. myself and employees are racers and run what we sell, as well as test for some of the parts manufacturers in a r&d format of street and strip use.
put all of this together with the best deals as a direct dealer and you will not find a better price, service, or knowledge of what you need for your car- right the first time.
I also manufacture all of the f-body suspension components to fit any of your needs. from race style heim-joint ends to any combination of polyurethane, adjustable or not, and always chromemoly components. you will find my components at the best deal out there as well due to buying manufacturer direct and low overhead costs.
If its under your car we have you handled! call, pm, or email me at eric@midwestchassis.com for the best deals you will find!
Two thumbs way up for what Eric said. i loved his customer service. i loved his price. and i loved his knowledge. and i love how he adj himself around your needs. and not adj you around what he sells.
Great Guy. Great Rear end.
eric, ill be needing a rear at the end of the year. i really want your midwest fab 9 but the problem is, is that i have a umi tq arm and relocation kit with all the hardware kit and pinion angle finder(m6). all of it is brand new never installed. i know i can't use it with any of the fab stuff that uses there own tq arm. i would really like to keep weight down an have a nice piece on top of it, but what do you suggest i do? i don't want to take a hit on selling this and get whacked on shipping too(stuff is heavy). i gurantee ill be doing business with you its just a matter of when. should i just go with moser 9" an keep it simple since i have almost everything?
2in narrowed each side (5.5bs)
35spline spool
nod center section
9"(which one?)
btw, does the standard moser come with a fill/drain plug and the 4 holes that are adjustable for the lca's?
35spline spool
nod center section
9"(which one?)
35spline spool
nod center section
9"(which one?)
35spline spool
nod center section
9"(which one?)
I do not believe the Moser's come standard with a drain/fill plug or relocation brackets.
Starts at 1600.00 shipped. housing features drain, sway bar brackets, 4 hole relocator style lca brackets, brake line clips, brake hose mounts, e-brake cable brackets, chassis brake hose adapter bracket, all as standard features at no extra cost. the chromemoly adjustable torque arm is available in short or long version. 28-35 spline axles, all same cost.
