3 channel convert to 4 channel?
All-
I'm underway on a build, and am possibly buying a pretty nice Moser 12 bolt. However, it is a 3 channel. My 97 Z28 is a 4 channel (ABS and TCS).
My question is this: Can the 3 channel Moser be converted to a 4 channel? What parts do I need?
I called Moser and spoke to someone in tech support, I was told that the sensor for the 3 channel in the top of the housing needs to be removed, and I'd need the reluctor rings for the outsides of the axles, along with a set of LT1 backing plates w/sensors. Is this all I need to do?
Did you ever get this worked out? What did you do with the 12 bolt 3 channel ABS parts? I'm about to start building one and would like to keep my 3 channel ABS working. I just started a thread asking about it too. Thanks, Jason
