What kind of York is on my 12bolt ....HELP
I bought the 12bolt off someone months ago and I forgot what kind of york I have on it.
Please help / instructions if poss.
Thank You
Thank You
Yes , that was a misprint LOL . Im looking to order a D/S this week but I need to know what kind of yoke I have on the 12bolt. Its either a 1350 or 1310 ????? If I knew the measurements of a 1350/1310 then I can find out , What I have ...
I BELIEVE a 1310 joint is the same as what's on the stock 10 bolt. I'm hoping it is a 1350 being as they are much stronger. Here is some info taken from Denny's Driveshaft website. Hope it helps.
What is the difference between 1310, 1330 and 1350 Series?
The "series" of a driveshaft or universal joint is determined by the actual dimensions of the u-joint. While the front and rear u-joint can be of two different sizes the shaft is only as strong as the smaller one. The 1310 series u-joint measures approximately 3 1/4 inches wide. The 1330 and 1350 both measure approximately 3 5/8 wide. The 1310 and 1330 series can have cap diameters of 1 1/16 and/or 1 1/8 inch or a combination of both sizes. The 1350 series has a cap diameter of 1 3/16 inch and the body and journals are bigger than the 1310 or 1330. Remember 1350 is almost never found in production car driveshafts.
LS1Tech Sponsor
I replied to your pm several minutes ago. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
