does syntheic oil help to quiet rear gears ??
Old 08-04-2010, 05:48 AM
Mac 2002 SS's Avatar
Default does syntheic oil help to quiet rear gears ??
A few months ago ,I had a 3.73 gear installed in my car . the install was great and the gear noise was very minimal. Now the rear noise about the same even after a few passes at the track.
I was wondering by using syntheic oil like, Mobil 1 75w-140 with the GM additive will help quiet down the rear a little more ?
Old 08-04-2010, 07:41 AM
fleetmgr's Avatar
If you had the gears put into a 10 bolt, probably won't help. The problem is this rear is so weak that it sort of rearranges itself. Oil cannot help a design deficiency.
