REAR END SHOPPING 750+WHP Q"s
Hey guys I'm looking for a rear end. I'm wondering who you would recommend and what gearing and what will be must haves for this custom rear end.
I'm going to be making 750+whp in my 94 z28 "Its Lowered" Full Global west suspension.. built 4l60E my turbo can go up to 1,400hp "room to let the boost bug move in!"
My main goals are to be able to hit 200+ mph and be able to run 9's at the track it will only see the track 2-3 times a year. It will be raced on the street every weekend! I would like to get a rear end that drives good and smooth with corners It will see the road course. It would be nice to have some form of LSD I was looking at A TRU TRACK but I dont think it will hold the HP I just seen the pictures of the busted Wavetrac what do I do? 12in or ford 9" 35spline? gear ratios 3.08?
I'm hope a sponsor can jump in here and hook me up on a great price and answer some questions for me as well! So that I can buy with confidence. Build it once right!
LS1Tech Sponsor
Take a look at the above link, and I would option it with the Wavetrac and the PST driveshaft.
Here is a video link on the M9. http://www.powertvonline.com/video_detail.php?mId=2901
Let me know if you have any questions. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
LS1Tech Premium Sponsor
If you have any questions hit me up with a PM or call and we can get you set up with something. Our housings come with a chrome-moly torque arm and cross member of your choice, either long or short version. The short version comes with a drive shaft loop built in.
Other standard features of our housing are drain plug, four hole relocator style lca brackets, stock style anti-sway bar mounts, brake line clips, hose mounts, and e-brake cable brackets(98-02).
LS1Tech Sponsor
Correct, and the Moser M9 with it's chromoly torque arm and transmission crossmember is the same weight as the 10 bolt. My Camaro cut 1.29 60 ft times with this rear on M/T DOT drag radials. Bob
__________________
One more option
Carfreaks,
Here is a link to the S60 bolt in rear for the F-body by Strange Eng. There are some up-grades listed but others You might be interested in that we can discuss if this is what You like.
http://centralracingparts.com/index....product_id=229
The parts line is 316-299-8427 and I have it forwarded to my cell this weekend like usual, call if You would like to discuss this.
Thank You,
Carl Loder
Thank You,
Carl Loder
LS1Tech Sponsor
__________________
LS1Tech Sponsor
__________________
Do you already have a good torque arm? If you do, the standard Moser 9 inch is a good way to go, and it is a lot less money. http://shop.brutespeed.com/Moser-9-I...c-Truetrac.htm Bob
Can you put the new and improved...Wavetrac in the standard 9?
LS1Tech Sponsor
I have the Global West track link bar. http://www.globalwest.net/tsc-26.html par hard rods upper and lower tubular arms. Fully adjustable coil overs...
__________________
LS1Tech Sponsor
Thanks, I pm'd you last night. Bob
__________________
Vendor special on Strange S60 rear end
Here is a link to Central Racing Parts first special in the sales/specials section.
https://ls1tech.com/forums/sponsor-s...60-f-body.html
Hope this helps some of You needing a new rear end for Your car!
Thank You
Carl Loder
Thank You
Carl Loder
