Gear swap?
Gear swap?
I have a 2001 SOM Z28 A4 with 22K miles on it and it has the 2.73 gears. The mods I have are: BMR SFC, Magnaflow catback, direct flo lid, and holley powershot filter. For my next mod I am leaning towards changing the gears. The car is a daily driver and I have pretty much decided to go with 3.42 gears. My question is,
Is it OK to change the gears alone, or do I need to get a torque converter at the same time?
I figure for GM gears and install kit it will cost roughly $400, plus install. But if I want a TC it gets significantly more expensive and will require more time to save up.
I know that a TC will help, but will I see a noticeable improvement with gears alone? If so then I can always add the TC at a later date.
thanks
thanks
