10 bolt
Here are my 2 cents. If your goals are bolt-ons around the 350 rwhp range on nothing more than a drag radial then you should be ok if all things are setup dead on. With a M6 car you can go with 4.10's but it does create a weak link that wasn't as critical before but some folks have run them with no problems just chose wisely. If you are looking at ET streets on nitrous or a monster head cam you might as well forget building the 10 bolt.
