Broken Currie t/a mount on 9"
I don't know if this has ever been an issue, and I'd be surprised if my car is the first to see it. Anyways, quick history. I got a 9" out of a Trans Am that supposedly ran 10's at one point. It was fine when I put it in my car. The last few weeks I've noticed more noise coming from my rearend. I thought a tire or bearing going bad. I finally pulled it apart Thanksgiving morning. I was a little surprised at what I found.
So my noise was probably my changing pinion angles. Either way, I now have a much larger problem. How does this happen? My car used to be 432 rwhp before the cam went bad, now it's stock. It never had a chance to hit the track. I'd hate to put another bracket on for it to do the same thing. I can't be sure, but it looks like this Currie bracket.
http://www.currieenterprises.com/ces...E.aspx?id=1595
Are there any other options? I'd hate to repeat the same thing over. I see Moser has a slick bracket, but doesn't sell it separately.
It can possibly be re-welded but the bigger problem is that the crack has split, so the bracket would have to be tweaked back and then welded. And then from there, the integrity of the metal has been compromised, I would rather get a new one and strengthen that. But I shouldn't have to do that period.
I'm going to remove the rearend tonight and see if I can find out anything as to why it failed. Then I'll send it to Currie. Since I wasn't the original buyer, it's non-unwarrantable. I'd hope I can at least get a break on a new one, something I shouldn't have to deal with on a stock car!!!
