how much gear oil for Moser 12 bolt
Old 04-05-2012, 01:27 PM
99monguse's Avatar
Default how much gear oil for Moser 12 bolt
I got three qts and 2 bottles of GM additive. How much will the housing take, 2 qtrs of oil and 1 additive?
Old 04-05-2012, 01:35 PM
Ethan[ws6]'s Avatar
Fill it until it starts to run out of the fill hole.
Old 04-05-2012, 02:15 PM
99monguse's Avatar
Do you guys put anything on the threads for the vent hose, where it threads into the axle tube...thread tape or anything? Should I fill the housing with oil before we install it or after?
Old 04-05-2012, 04:48 PM
Ethan[ws6]'s Avatar
I didn't put anything, just made sure that it was a snug fit. Also, it's easier to fill when it's out but that'll make it heavier to lug around while putting it in lol. I filled mine after it was in no big deal.
Old 04-14-2012, 06:43 PM
edge04's Avatar
I assume you should feel oil if you stick your finger in the upper cover hole or should it only be to the lower (smaller) hole http://www.moserengineering.com/othe...lt-gm-car.html Just parked my car on a very slight uphill slant and oil leaked out of my diff. Cover bolts don't seem lose, maybe gastket bad, but out of nowehere, puddel. Not drip before that. Seems odd. Sorry for the highjack
Old 04-15-2012, 11:48 AM
soco80p's Avatar
Unless you have a large aftermarket cover, it will be two bottles plus one of the posi additive (if needed)
Old 04-15-2012, 04:38 PM
edge04's Avatar
how much did it take? Mine must have been overfilled, I loosened the lower drain plug and it started to come out which I think means full??
Quick Reply: how much gear oil for Moser 12 bolt
