I purchased a Spohn driveshaft and this is what happens!
Well fellas here is what happens when using a Spohn, I contacted them and I told them what happened and I sent the pictures you see below and the you'll see their response. I ordered this d/s through the ws6store and as you can see I ordered the one that applies to me. Spohn's defense is you should of measured and that strapping a car on the dyno causes "stress" well no kidding but more that being on a street? Really? Well then if I have to measure why would you sell your d/s like this? This is what kills me,
It's not the vendors fault but why would Spohn advertise like this?
http://www.ws6project.com/user_stor/...g/driveshafts/
http://www.lmperformance.com/78229/1.html
Just an example
If you still have to measure?! I also called PST and strange this morning and they said they DO NOT make theirs shorter! They both said they make it to exact sizes that you order. Now I'm out a Trans with no days off because of these NATO clowns and All cops have to be on the streets or close by! All I wanted was to have my car ready by memorial day weekend to celebrate it with my family!
What do you guys think?
This is the email from Spohn
From tech@spohn.net
The output shaft on your transmission broke, it's actually a very common occurence when strapped down to a chassis dyno. A chassis dyno places a lot of stress on the drivetrain.
It had nothing to do with your driveshaft. The driveshaft is exactly as it should be from your pictures. They are supposed to be a bit shorter than the factory driveshaft, you need a little more slip yoke travel for high performance applications. This is how we have built them for 13 years and how any performance driveshaft company builds them. With that said it is always the installer's responsibility when installing any driveshaft on any car to check for proper engagement, etc. before driving the vehicle.
It was just a matter of the stress the chassis dyno put on your transmission, it happens unfortunately.
Here are the pics:
Just an example
From tech@spohn.net
Here are the pics:
if you checked aftermarket rear then that sounds like a ordering issue that they got wrong. Do you have your receipt still. thats a shitty situation, hope you get it resolved
I wonder if the tailshaft bushing walked outa the trans, do you have a adjustable torque arm, was the pinion angle right as it looks like it was a vibration causing that. Sure is a shame
LS1Tech Sponsor
A nine inch really needs a one inch longer driveshaft that what a 10 bolt and 12 bolt requires. Check out the x dimension on the diagram at this link. http://shop.brutespeed.com/PST-DRA35...-PST-DRA35.htm
45.25 is the dimension we use for 9" rears. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Thank you Bob that means a lot!
As soon as I get my trans gets repaired and I send this d/s back I will be calling you sir!
I just hope others like me see this so they don't hop on a vendors site and order a d/s thinking its the correct size, because it won't.
Was there any vibration? An out-of-balance driveshaft could be a possibility of breaking the output shaft.
How did the splines look on the shaft and yoke? Too little engagement likely would have just stripped out the splines on one or both pieces.
I think you just simply had an output shaft failure. Be sure to inspect it good for stress signs at the yoke when you get that trans torn apart, although I doubt there will be any. It happens and yes it sucks! I had a T400 break an output shaft in a plow truck, blade up and minimal acceleration. Snapped at maybe 5 mph.
What was the torque arm angle?
The first and second picture posted above, is that indicative of how far the driveshaft was slid into the output shaft and ran? Or is that just the aftermath and pulled out to show the seal broken etc?
When I swapped my bigger yoke onto my new PST driveshaft we didn't get the bearing caps perfectly centered and it made quite a bit vibration even though it was just about perfect. The driveshaft looked like it was oblong when under throttle but it was the bearing caps that made it un-centered. We took them off and re-centered and everything was perfect after that.
Not sure the exact measurement but I had asked Straightline and they said it was ok.
The pictures are the aftermath and my deal and everything else broken.
The driveshaft was shipped with the Trans yoke already on. All I supposedly had to do was slip it in and bolt it down.
It clearly shows in pic #3 that the d/s are the same length, pics #3/4 show slip yokes are not. You had some doubt about slip shaft engagement when you asked about seal running close to the end. Then you ran the car 15-20 min with a bad vibration, come on now!!! I feel for ya bro but your blame is misplaced. I have alot of spohn susp parts on my car with no complaints at all. Will probably use their d/s when I upgrade from stock. Good luck and hope everything turns out OK! Larry
The 3/4 of an inch less engagement doesn't break output shafts (unless you were already borderline which you wouldn't be on a stock shaft). Whatever the vibration was probably did.
