Moser 12 bolt trips ABS Inop/Brake lights
Old 06-30-2012, 08:27 AM
02 SSilver Bullet's Avatar
Default Moser 12 bolt trips ABS Inop/Brake lights
At the time this rear end was installed there supposedly were no harnesses to allow proper connection for ABS. So, technically speaking, the rear has no ABS right now and is tripping the ABS Inop light on the dash along with the hand brake light. Anyone aware of how to fix? Know of a harness I can use? I believe it needs a 4 point harness. It came with a three point.
Also, cruise control is inop.
Old 06-30-2012, 02:11 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
LS1Tech 20 Year Member
I take it you bought this rear used and you are saying it does not have the ABS option on it?
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 06-30-2012, 10:27 PM
That's right. Can you help?
Old 07-01-2012, 06:37 AM
LS1Tech Sponsor
The rear would not have the exciter gear in it if it was not ordered with the ABS option. Retrofitting it would be expensive, the entire rear would have to come apart. Your best bet is to forget having ABS, and remove the bulb staring at you on the dashboard, or sell the rear and get one that has ABS. Bob
__________________
Old 07-02-2012, 04:19 PM
2000RATA's Avatar
I might be able to help you. What carrier do you have and gear ratio? I havethe the Moser in my car also bought used. My car has traction control so it does not used the sensor and reluctor wheel on the carrier. If you had same carrier I would trade. I have to pull mine to change gear ratio. I have the Eaton.
Old 07-02-2012, 04:50 PM
Default Carrier
Not sure what carrier I'm using but I'll check. I don't have traction control on mine either. If we did have something worked out and traded, how would you want to do it?
Old 07-02-2012, 05:04 PM
2000RATA's Avatar
You pay for shipping if you have the same carrier. I don't use these features so you can have the sensor and carrier. Moser usually put Eaton 4 series carriers with 33 splines. If you have this to trade and will pay shipping both ways we are good. I can take pics and I have a build thread in the forced induction forum which validates why I am pulling it soon, the carrier that is. Not the whole rearend. I don't know if there is a knockout or plug or what where the sensor would go on yours you will want to look into that. It may require machining. Maybe more work than you want. Just offering.
Old 07-05-2012, 11:07 AM
Yeah, I don't know if I'm to more work on this rear end. To be simple, it works great just don't like the ABS and BRAKE lights on all the time. Still, the car stops pretty good without the ABS working and the cruise control I really don't use anyway. Let me think about it some more.
Quick Reply: Moser 12 bolt trips ABS Inop/Brake lights
