3 channel on a 9"
3 channel on a 9"
i am looking to buy used moser 9" or a used moser m9 the problem niether have the abs sensors what would i need to do install it my car has a 3 channel set up and can i use any of the parts off my 10 bolt
LS1Tech Sponsor
The easiest thing to do is to go ahead and install the rear and just not hook up the ABS. If you don't hook up the ABS on the rear, the front ABS won't work either. Basically you would be back to old school brakes. You will have the ABS light staring at you on the dash, which cannot be tuned out. You can pull the bulb or paint the bulb black, etc. To install ABS on the rear would entail setting up the center section with the exciter ring, and drilling a hole through the top of the housing where the pick up goes. I would not recommend trying to do this. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
