HELP diff fluid change ASAP
Trying to change my diff. fluid for the first time, i have all the bolts off of the cover but for some reason the cover is still on good and tight, why is this? Can i pry it off w/ a flat head screwdriver or is there something other than the 10 bolts holding the cover on? Also once i do get it off, is there anything else a first timer should know about diff. fluid changes? Thanks
GM recommends that you use synthetic gear oil and the additive that you can pick up at your dealer. the cover should come off with a little persuasion of your choice short of destroying the cover
Originally Posted by Rice Burner
I have to do this soon too. Do you have the car up on jacks or what?
