can i put a TCS rear end in a non TCS car?
Old 04-12-2004, 10:22 PM
kickassT/A's Avatar
Default can i put a TCS rear end in a non TCS car?
hey guys. my buddy has a rear end with the gears i want in it i can get cheap, but it has traction control on it, and my car doesn't. is this a problem? if so, what do i have to do to make it work? thanks guys.
Jordan
Old 04-12-2004, 10:39 PM
SUX2BU's Avatar
the housings are different. you could just swap out the guts but make sure you put the reluctor ring off of your diff back in your car. its about a two hour job.
Old 04-14-2004, 11:11 PM
sercastiK's Avatar
i also wonder about this, how much odification would it take to just use the whole assembly?
J
Old 04-15-2004, 08:21 PM
SUX2BU's Avatar
way too much! you would have to drill about a 1 inch hole on top of the rear in the EXACT position the sensor is then tap a small hole next to it to hold it in place. then you would have to take the rear completly apart to get the ring gear off of the diff , then sandwich your reluctor wheel between the ring gear and the diff , put it back together, fill it back up with fluid, then swap the whole assembly in to your car.
Old 04-15-2004, 08:25 PM
SUX2BU's Avatar
you can put a NON TCS rear into a TCS car but you have to put your original backing plates, and your original axles in it (NON TCS axles don't have the machined lip for the reluctor wheel). which means you gotta pull the cover off, pull the axles out, take off the backing plates install your TCS backing plates, install your TCS axles, and plug the hole on top of the rear end or just leave the sensor in, it wont hurt anything.
Old 04-15-2004, 10:15 PM
Pathological Modifier
Ryan K's Avatar
It will bolt right in but you'll lose ABS.
Ryan K.
Old 05-18-2004, 12:18 PM
BattyV6's Avatar
Bringing up an old thread, but what are (or are there) distinguishing visual differences between and non-TCS rear and a TCS rear?
-Andrew
Quick Reply: can i put a TCS rear end in a non TCS car?
