Rear Axle problem?
Old 04-13-2004, 05:11 AM
666ws6's Avatar
Default Rear Axle problem?
With the car up in the air, driveshaft disconnected, I noticed my rear wheels spin independent of each other. If I spin the LH rear, the RH doesn't move (and visa versa.)
I thought these Auburn rears were supposed to act like a posi-rear. (spin one tire one way, the other goes the other way.)
Is this a problem?
Taking off on a turn sometime causes the engine to rev high and it feels like the rear isn't grabbing (but it's done that since day one.)
Any help is much appreciated!
Old 04-13-2004, 10:03 AM
2xLS1's Avatar
You don't have an Auburn carrier unless you changed it yourself. A 00 WS6 came stock with a Zexel-Torsen carrier and what you describe your car doing is normal. http://www.torsen.com/products/T-2.htm
Old 04-13-2004, 01:59 PM
666ws6's Avatar
Thanks, you're right, I couldn't remember which one. Thanks!
Old 04-14-2004, 06:26 PM
NHRATA01's Avatar
If its an open rear, when you spin one tire the other will spin opposite rotation.
