How off will it be
Old 02-23-2013, 01:41 PM
ssteven's Avatar
Default How off will it be
My rear broke bigtime. I have 3.73 A4. funds are tight so i found a complete rear end with 2,73s. I will need to drive it for a week until i get the pcm reflashed. How many mph will speedo be off? higher or lower? I know shift points will be off.
Old 02-23-2013, 09:01 PM
murphinator's Avatar
it will be off around 25% , I would be most concerned with whether rpm and mph will be met to initiate shifts in the tune thats a big gear change to expect the tune to absorb , it would suck to have to add a trans to your budget...
Old 02-24-2013, 09:04 PM
1981TA's Avatar
...and may also put you firmly in "ticket territory" if you don't pay attention. When your speedo says 65, you'll be over 80.
Old 02-24-2013, 09:25 PM
FirstYrLS1Z's Avatar
65 speedometer indicated speed will be 89 actual speed.
47 speedometer indicated speed will be 65 actual speed.
Use a GPS unit to determine actual speed.
Old 02-25-2013, 01:07 PM
ssteven's Avatar
If it works out I will only have to drive it maybe 1-2 days.Thanks
Quick Reply: How off will it be
