Cant get the pin out to remove axels HELP!!!
Old 03-20-2013, 07:33 PM
Justinktm's Avatar
Default Cant get the pin out to remove axels HELP!!!
i removed diff took off the 8mm and that little pin wont remove its being blocked by the gears what should i do ? i need the backing plates for my 9inch
Old 03-20-2013, 08:04 PM
FirstYrLS1Z's Avatar
In your sig,4.10 gears are indicated. The 4.10s' were installed using the stock 'paddle' which was forced in past the ring gear during assembly. 4.10s' require a SLP split paddle or a modified 'ground' paddle. It's easier to force a stock paddle in than to remove it.
Grind the tips of the ring gear teeth until the paddle will come out. Where the teeth tips will end up being removed will be out of the 'pattern' anyway. I've done it.
Old 03-20-2013, 10:12 PM
Justinktm's Avatar
Sweet ill try it with dremel
Quick Reply: Cant get the pin out to remove axels HELP!!!
