Rear Wheel ABS Sensor
Ok my question here is I am working on a 1999 T/A that was originally supplied without traction control. I am getting a ABS light and code. I have contacted G.M. about a replacement. I have googled the P/N which is 10456115 and it lists it for a couple of different gear ratios. Does anyone know if it is the same for all gear ratios? The brakes pull hard to one side and the light is on. We have replaced all brakes, calipers, and installed new stainless steel brake lines. we have bleed the brakes petal is very firm. The hard pulling was the original problem before any new parts were installed.
