What's Needed For A 9" Rearend Swap?
Old 07-21-2013, 04:26 PM
Chevyboi09's Avatar
Question What's Needed For A 9" Rearend Swap?
I have finally come in to some money and I'm just about ready to order my Moser 9" from TSP for my 2001 Camaro. I plan on ordering everything that i need at once. I know I will need a new torque arm and driveshaft for the 9" rearend length. Im not sure on what else i will need tho. Below are the options i am going with from TSP. Links with preffered parts would be nice. Thanks
Rearend Options:
Gears-3.75
Differential-Wavetrack 31 spline
Pinion Support- Aluminum Daytona Pro/Street
Wheel Studs-Standard OEM
Drain/Fill Plugs-Installed
4 Channel ABS
Back Brace-Install
Brake Option-Factory
Extreme Axels-No
Lower Control Relocation Bracketss
Rearend Length-Standard
Sway Bar Mounts
Case-Nodular
Old 07-21-2013, 04:35 PM
alexus6798's Avatar
Looks like you have everything covered. I would upgrade the studs though if you plan on tracking it a lot or just for piece of mind. Might want to give Bob at Brute speed a call.
Old 07-21-2013, 04:41 PM
Chevyboi09's Avatar
Thanks. Would the ARP's standard size be alright? It's my DD but will definitely see a lot of the track. I'm not sure if the wheels I have really matter when deciding on studs but, I have the OEC 17x11 ZR-1's. Any recommendations on studs?
Old 07-21-2013, 04:46 PM
alexus6798's Avatar
I got ARP 1/2"x20x2". If they are using ARP for the standard size, it might be ok. I upgraded after researching and seeing people were breaking the studs provided by strange.
Old 07-21-2013, 05:02 PM
Chevyboi09's Avatar
Actually, it'll be from Texas Speed and Performance. They just offer factory? wheel studs. I'd have to order any other studs that i decided on. i.e. ARP. With the studs you went with, I'm guessing you had to order different lug nuts?
Old 07-21-2013, 05:08 PM
alexus6798's Avatar
Yeah, had to get different lugs also. I had to get open end because I'm running 2" long studs. I can't run my lug caps anymore but no big deal. I saw that you were ordering from Texas speed. Maybe give them a call and they could get them and its just not showing on the website. My studs had to be ordered separately and shipped to strange to be installed.
Old 07-21-2013, 05:24 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Thanks, I appreciate it! To the OP, please check out my shipped prices at this link. http://shop.brutespeed.com/Moser-9-a...Ends_c2632.htm Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Quick Reply: What's Needed For A 9" Rearend Swap?
