10 bolt how wide?
The axles are 32" long and they butt up against the 3/4" diameter cross-pin in the differential. Add 1/4" per side for the rotors and you get 65 1/4" rotor-to-rotor. That pretty much matches the link provided above since I had the distance from the housing flange to the axle flange at 2 5/8" or a little more.
