need help with rear end setup
got the pinion and ring gear on but have trouble with shimming the carrier. If i shim it right, but then tighten down the carrier bolts to the right specs the thing wont turn like the gear teeth are hitting the bottoms of the gears' teeth. What do i do?????
I called jeg's and they dont even sell the carrier shims, just pinion. With the shims on the right sides the carrier wont spin by freehand when the carrier bolts are torqued down.
Well, got the gears installed and took it for the 20 mile break in. On turns, including very slight ones, it clunks REAL bad. Im thinking differential like spider gears? It does it even worse in reverse and turning. HELP
