anyone running synthetic in there 12-bolt
i woundn't. rear ends really dont need it. regualar oil will last 100,000 miles but i would change it evey 25,000 anyway. it is not worth the cost unless you got lots of extra money and you car already has everything else you can put on it.
Originally Posted by BTL FED
Redline is full synthetic, it is all I will use in my motor and my rear
for the motor, i would definently reqemend it since it deals with alot more heat and friction. i use moble 1 in mine.
Originally Posted by INMY01TA
Moser and Strange do not recommend Syn. for use with their Eaton posi's. There's no need for it anyway so why do it. ANY 80/90 gear oil will do the job just fine.
Actually the Moser will uses between 2.25 and 2.5 bottles. If you use the side fill plug, you'll get about 2.25 in before it starts coming out.
I use the fill plug on T/A cover and put 2.5 bottles in... I also put in two 4 oz. bottles of limited slip additive as well.
