Weight Comparison - Stock vs MWC 9"
Old 04-22-2014, 09:14 AM
No Juice's Avatar
LS1Tech 20 Year Member
Default Weight Comparison - Stock vs MWC 9"
For those that care, I still need to weigh the stock trans x-member, will update later
Part........................Stock(lbs)............ ..MWC(lbs)
T/A............................25 (UMI).............18
Sway bar brackets.......3.5......................n/a welded on
Driveshaft w/u-joints....13.5...................13.5
Rear (no fluid)............156.....................182.5
Trans X-member.........10........................5
_____________________________________
Totals........................208................. .....219
Here is what I ordered
MWC 9" Std width
Backbrace
Powder Coated
Strange Alum HD Pro Center
S-Trac
35 Spline
Long T/A
PST 3.5" Alum Driveshaft
Old 04-22-2014, 08:12 PM
z-maro's Avatar
Man that UMI arm is heavy! My stock T/A weighed 17 lbs, MWC T/A (for the 10 bolt) was ~18.5, stock x-member 9 lbs, and MWC X-member 6 lbs.
Totals: Stock 26 lbs, MWC 25 lbs. (Note that this was with a crappy bathroom scale, but looks to be close to your measurements)
Old 04-23-2014, 07:25 AM
No Juice's Avatar
^^^lol, yeah I used the same crappy bathroom scale
Old 04-23-2014, 09:21 PM
No Juice's Avatar
updated.....
Old 04-23-2014, 10:04 PM
HioSSilver's Avatar
good info. My crappy bathroom scales was broke when I put in my mwc fab 9.
Old 04-24-2014, 09:10 AM
BrntWS6's Avatar
MWC has some light stuff. I weighed everything on my install and the 9" with long T/A, crossmember, PST DS etc ended up only being ~ 15lbs heavier than the stock parts. And that was with the iron center section.
Quick Reply: Weight Comparison - Stock vs MWC 9"
