carbon fiber composite driveshafts??
Does ANYONE still make a cf driveshaft for the '98-'02 LS1 f-bodies, besides the special made to order, $1K, Driveshaft Shop deal??
Is ACPT even still in business (their site does not come up for me at all), or anyone else who used to make these for our cars?
Before all of the naysayers come on here and blast these products, let me say this car will NEVER BE USED for drag, or even 'roll' racing again as long as I own it, it IS used for autocross/road racing/open tracking, and I want this item to help reduce the ring and pinion whine which most say our 10 bolts MUST have (even with proper set ups) due to the way our cars' suspensions/drive lines transmit NVH into the cabin area.
My thoughts are that since cf is a SUPERIOR damping material to EITHER DOM, or chromoly steel OR aluminum alloy, it will transmit less of the ring and pinion scream into the interior.
i got a quote from the driveshaft shop but it wasnt 1k total out the door with new joints and yoke was 799. Sill not cheap but much better than the 9xx that pst wanted. Plus I like the driveshaft shops design better. Their yoke actually threads into the carbon tube and goes in further. where the pst and acpt were just pressed/glued in which caused quite a few failures
I was told that quote by a local shop, so they may have included some 'markup' into their price.
The only other drawback is that I have heard some bad 'internet stories' about D.S. alloy and steel shafts showing up TOTALLY and completely out of balance, which IS a problem as NO shops around here will even touch an aluminum driveshaft, let alone be able to balance one.
I can only imagine that for a cf shaft, it would be 10,000 times more difficult to find a balancing shop, so it HAS TO BE perfect right out of the box!
LS1Tech Premium Sponsor
We use CF shafts in everything from high 5 and low 6 second Pro Mod cars to LSX Drag Radial all way to street racers. The bonding technology has come a long way in the recent years and has proven to be very durable and much safer than any metallic shaft. Most CF shafts I have seen do not require much of any added balance weights.
I ask because I had a 3.5" aluminum shaft in this before, and it did scrape against some parts when the suspension/unibody/torque arm/rear axle was in full flex/extension/twist.
This would be a VERY expensive (but yes, safe) disaster with a cf shaft.
WHY would drag race orgs even require them on a cf driveshaft equipped ride, as they just 'broom' when they come apart? (To keep the alloy yokes in place maybe?)
What concerns me is that the 3.5" alloy one I had in this car was contacting other parts under there (torque arm, possibly the 3.5" intermediate pipe, etc.).
So how would one 1/4" LARGER not make contact with these same parts??
The ACPT has been in my car for years. Bought it to run ORR events, and have been 170 mph smoothly.
That is as about close as they get (stands under axle) but that 3-bolt flange has to go.
It is the smaller one they offered. I'd have to measure it to quote the size. I knew the car would never make insane power, but was driving close to the critical speed of the OEM shaft, and didn't want a failure or any shake cruising at 165.
I am in the same boat as I am NOT going to be chasing mega power like most on here (NOT needed, or even allowed in the rules of most road racing sanctioning bodies).
It will NEVER be more than 425 ponies/torque to the wheels!
But it will help with the constantly changing speeds of open tracking/autocross, and it WILL kill some more NVH than any other material out there.
