MWC 9 removing fill plug?
There a trick for removing the fill plug then getting it snug for the midwest chassis ford 9 with the strange center section? Sockets don't fit and neither do wrenches, kind of a pain in the ***.
Anyone have any tricks?
A month of the car sitting and I finally got around to this. Welded an aluminum nut on the end of the strange 10an plug. Now I can actually fit a wrench on it to get the plug on and off.
Looks like garbage, but whatever at least it won't suck to take it off.
Strange 9 fill plug
Hind sight a 10an plug with a hex on it would have been better and only cost me like 5$, MWC you may want to spring for these for future customers.
***EDIT*** The below isn't an o-ring boss (ORB) fitting. Different taper on the fitting and the ORB fittings use a rubber o ring. I can't find any ORB fittings in 10an that hex open
http://www.ebay.com/itm/AN10-10AN-AN-10-BLACK-FLARE-HEX-HEAD-PORT-PLUG-FITTING-ADAPTER-/130799570881?pt=Race_Car_Parts&hash=item1e74430fc1&vxp=mtr
Something like the BELOW should actually work, but 40$ from AU. Not sure if anyone domestic makes them.
http://www.ebay.com/itm/Speedflow-10ORB-10-O-ring-Boss-Port-Plug-Block-Off-Hex-Fitting-814-10-/140970687407?pt=AU_Car_Parts_Accessories&hash=item20d281fbaf&vxp=mtr
Strange 9 fill plug
