recommend a gear
recommend a gear
I don't think I'm going to have enough gear to get through the 1/4 on the bottle. but I'm not sure what gear will get me there. 3,200 ish race weight, 28" tire, 4l65e, and ford 8.8 rear end. my current N/A 1/8 time is 6.80 at 101 with a transmission skipping 2nd and shifting from first to third. I plan to put a 200 shot on top of this combo. a rough guestimate on the 1/4 trap speed on motor is 125 (ish) I'm on a 4.10 gear. what gear range do I need to be looking at?
I'd agree with the 3.73 on the 28" tire. I have 3.73's and with a 275/40/17 (~26" tall) tire was somewhere around 6000rpm @121.xx mph in the quarter. This was on my first pass, on my second pass I spun and then my alternator burned up so I don't have any better data to go off of. I think with 4.10's you'd be hitting the rev limiter somewhere around if not before your guesstimated trap speed.
Check this link with your numbers to see where your RPM & speed will be with different gears
http://www.wallaceracing.com/gear-speed.php
