Torque Arm Pinion Angle (with radials?)
So I'm about to install an adjustable torque arm and I know you are supposed to set the pinion angle with the wheels on the ground and suspension loaded.
What I don't know is whether I should put my drag radials on that I intend to use at the track or leave my street tires on to set the pinion angle?
I doubt there would be much difference, but I wanted to check...
LS1Tech Sponsor
You won't see much of a difference but if they are 28" tall I'd put them on. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Shouldn't matter if you are setting pinion angle off the driveline. I use my harmonic damper as a reference point for drive line angle. Then set the pinion angle according to that number.
Thanks guys. I understand pinion angle a little better now and realize the tire doesn't matter. Still learning.
Is -2 degrees what most people go with?
